programmatically add packed library to a user palette
I built a set of functions in a packed library. In that packed library I put my .mnu file.
I can manually add my packed library to the LabVIEW palette without any problem. It works.
Now I want to build an installer to distribute my packed library to the developpers in my company but I'm not able to insert the packed library programmatically into the LabVIEW palette.
Does anybody know how to do that ?
Christophe
(3,873 Views)
I am working with NIcRio -9024 I have successufully interfaced NI9205 module , Now  I want to interface NI9870 module with serial interface I am ttrying with the examples given in the website but they are not working can any one please send me small example of loopback interface with NI 9024 with NI 9870 serial module
rupesh
(3,866 Views)
Hello Christophe,
This tutorial will guide you through the process to configure the build specification settings and build the packed project library:
http://zone.ni.com/devzone/cda/tut/p/id/3303#toc2
If you need further information, let me know.
Have a good day
(3,850 Views)
hi thanks for reply
can you suggest me  some method to just interface 9870 with cRio 9024 in loopback mode I am not getting it just simple example for loopback
rupesh
(3,847 Views)
Sure we can answer your question and help you with your cRIO, but please, post it in the right forum:
http://forums.ni.com/t5/Real-Time-Measurement-and/bd-p/280
Have a good day
(3,839 Views)
how can i post there is no option for new message ??
(3,836 Views)
You can post by selecting a topic in the precedent link or you can use the next one:
http://forums.ni.com/t5/forums/searchpage/tab/message?submitted=true&type=message&q=rt&page_size=50&...
I hope this helps.
Regards
(3,830 Views)
