programmatically change tool tips
I want to display a bunch of data in a small area so I built a cluster with 2x7 vertical sliders. There are no visible labels and they are packed as tight as possible to save real estate. To read what one of the sliders represents I gave each of the sliders a tool tip. So the +12V slider has a tool tip of "+12 V". That worked fine when the cluster elements were fixed. Now I need them to be assignable. Can I change the tool tip at run time?
Norm
(3,169 Views)
Accepted by topic author Viper
Wow, it turned out to be a lot easier than I thought.
(3,167 Views)
