programmatically creating parallel loops
Hi
I have a VI which i want to call a number of times defined by the user. so i can simply put the vi in a for loop and call it accordingly.
now each time the vi is called, it executes data independently of the previous call. Hence i want to run them in parallel using reenterant subvi property.
However the no of times a vi needs to be called can be determined only during run time..
How do i do this?.. hope i have made my question clear
thanks in advance
(4,568 Views)
Accepted by topic author Ujjval Shah
What does the subVI do? Is it supposed to run continuously? Does it have a loop? If so, then you should launch the VI using the VI Server functions. This allows you to launch the VI and then go to the next iteration of the loop to launch a new instance.
Check the examples that ship with LabVIEW on using the VI Server to launch VIs dynamically. You will also find numerous examples in this forum.
(4,557 Views)
Hi smercurio_fc,
Thanks for your reply.
I tried using VI server reference.
The subVI has a for loop inside it
However i am not getting the desired result. According to what you said, using the vi server reference in a loop should launch the subVI  and move on to the next iteration and then call another clone of the subVI- correct me if i misunderstood-.
and if i understood correctly then this is not happening cause LabVIEW is waiting for this called subVI to execute completely and then only it moves on to the next iteration. I want multiple instances of the same VI to run in parallel
initially i thought it might be a problem of the subVI being non-reeenterant, but even after making it reenterant, i am having the same problem.
pls share your thoughts and help me.
(4,449 Views)
ok, i just figured it out.
the example of multiple pop ups came into handy.
Thanks!
problem solved
(4,437 Views)
