programmatically disabling a front panel button
@CLAD_in_training wrote:
This question is similar to the one above. I have an application that has 10 tabs with roughly 10 buttons on each tab. What I am trying to do is disable buttons, tabs, or vi application when another test is being performed. Is there a way other than creating a property node and disabling for every button?
Thanks in advance!
Also, Look at subdividing your task into separate vi's I am sure that those tabs are likely better implemented as different VI's in Sub Panels
Message 11 of 11
(838 Views)
