programmatically generating controls
In this thread
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=236#M236
you will find a set of picture control examples. In post # 4 I give a link to the "Obfuse code" thread where in post #52
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=147#M147
I posted an example that can be used to create an arbitrary number of controls and postition them such that they are performing a random walk.
This example gives you most of what you need to implement virtual controls in LV.
Ben
Message 11 of 13
(1,673 Views)
And this link will show the XControl example.
Ton
My LabVIEW Ideas
Message 12 of 13
(1,606 Views)
one more comment:
when you don't need switches to represent the booleans you can still go with numeric indicators!
Just switch the representation to 'binary' and set the number of digits with a property node...
When you only need to display values you can also use string indicators. Format your values using 'Format to string' and a corresponding format string like '%02b %02d %02b'  (for 2 bits, integer from 0-15, 2 bits).
Message 13 of 13
(1,600 Views)
