programmatically launch FPGA compilation
I too am interested in this.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 11 of 15
(1,346 Views)
Looks like LabVIEW 2018 has files for automating LabVIEW FPGA builds:
C:\Program Files (x86)\National Instruments\LabVIEW 2018\vi.lib\rvi\CDR
ALE Consultants
Message 12 of 15
(1,336 Views)
The programmatic compilation VIs under C:\Program Files (x86)\National Instruments\LabVIEW 20xx\vi.lib\rvi\CDR are completely undocumented and password-protected, so it is very hard to troubleshoot problems that arise.
And in our limited experience with attempting to leverage these files, the behavior is wildly inconsistent. Calling "C:\Program Files (x86)\National Instruments\LabVIEW 20xx\vi.lib\rvi\CDR\niFpgaBuild_Compile.vi" multiple times on the same source code sometimes actually compiles and other times apparently does nothing at all (including not throwing any sort of errors).
Are there any other tools available to do the compilation, or is it even on the roadmap to try to provide a real alternative? As it stands now, these tools are pretty unacceptable. Can anyone from NI proper comment?
Message 13 of 15
(1,263 Views)
This VI just saved me years of my life
Message 14 of 15
(1,146 Views)
@DAQjr wrote:
Hi Ray,
I've thrown together something that works for me to build multiple FPGAs in multiple projects with multiple build specs for a single VI.  In my case, I build the same VI for several targets and with different Conditional Disable Symbols, so I have to resave the top-level VI in the context of the target I'm about to build.  It could be improved to find all the dependencies and save them, in case there were Conditional Disable Structures in subVIs as well as the top-level VI.
It's not pretty and it may get at references less directly than possible.  Any clean-up suggestions on the VI Server code is welcome.
Hope this helps,
-Joe
This VI just saved years of my life
Message 15 of 15
(1,144 Views)
