programmatically modify type def
I have inherited aprogram that I am trying to modify with the least possible amount of change.  One of the controls is used throughout all of the sub-VIs, and it is a type def.  It is a cluster containing three clusters.  I want to programmatically modify the data entry limits on one of the numeric controls in one of the sub clusters.  I can't seem to get to the point where I can create a property node to do this.
Jim
LV 2020
(3,635 Views)
Accepted by topic author lmtis
The datatype you get from the Controls[] property is of a generic control. You have to cast it to a cluster.
(3,627 Views)
Thank you smercurio, you are Kudo-riffic!  After a year away from development I am finally getting back in the saddle.  Your help is much appreciated.
Jim
LV 2020
(3,608 Views)
