programmatically writing listbox
Hi seniors,
I am developing an application which allows the user to configure various parameters of DAQmx task and writes those parameters to the multicolumn listbox.
The attached vi allows the user to configure only one channel and adds to the list, suppose the user try to add one more task in the list , then it replaces the previous task.
How to develope the code in such a way that when the user configures second channel and clicks "add to the List" , then it should be written in the second row of the listbox instead of replacing the first row.
Kindly guide me seniors.
(3,417 Views)
You're half-way there. Eliminate the for-loop, as that does nothing. Get the value of the table (you already have the control there, and use Build Array to add a row.
(3,409 Views)
