programming Hx711 with labview and MyRio
Hello.
I need help programming a labview code to read form a HX711 connected to a load cell. I have seen a lot of examples of people using arduino as a DAQ system and labview just to see results but my project is using MyRio as only DAQ system. any solutions?
thank you in advance.
(892 Views)
@Joseantoniodemiguel wrote:
Hello.
Here is great place to start:
https://education.ni.com/teach/resources/92/ni-myrio-project-essentials-guide
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(842 Views)
Do you have any experience using myRIO?  It is a great little piece of hardware, but the software/hardware interaction can be a little tricky.
  • You must be running a compatible version of LabVIEW.  I'm not 100% certain, but I think you might need to be running 32-bit LabVIEW.  I know it runs with LabVIEW 2017, 2019, and 2021, but not very well with 2020.
  • You need a "matched" version of the myRIO Software Toolkit.  [There is no 2020 version, for example].
  • Have you been able to attach the myRIO (via its USB cable) to your LabVIEW PC and have it show up in MAX under "Remote Systems"?
Bob Schor
P.S. -- I thought I remembered posting a longer response yesterday evening -- maybe I was dreaming ...
(818 Views)
