01-20-2009 03:23 AM
01-21-2009
07:18 AM
- last edited on
02-04-2026
01:54 PM
by
Content Cleaner
Dear Maria Grazia,
as Centerbolt told you in your previous message, a good solution would be to use the Modbus library, but as I see on the AC650V series specification page, the Modbus Box is optional for these drives; I suspect you don't have one, so the only solution is to program digital and analog inputs and outputs through your DAQ cards in order to drive the inverter.
From what I understood from your description, I think it would not be so difficult to implement it, but I'm afraid you won't find an already developed ready-to-run solution.
I think you would have to acquire a signal from the displacement transducer through an analog input card and process the signal in a loop in order to generate the right outputs for the inverter: in order to understand how the inverter is driven, you should look at its documentation and specification. From the general page of the AC650V drives, they seem to have analog inputs for speed setting and digital inputs for start/stop, for direction and for preset speeds. So you should generate the right digital outputs and, if you want to continuosly change the speed, an analog output.
I can't be more precise, but I encourage you to look at the Getting Started with NI-DAQmx guide and try to implement what I suggested you.
If you'll have more specific problems in doing it, we're here to help you; but please be specific about the single problems you encounter.
Good job
Giorgio
