programmlly dropdown the ring or combobox
hi all,
i want to programlly dropdown the ring or combobox,just like click on the ring or combobox then get a dropdown list,how to do this??............thanks
(4,402 Views)
hi,
you can follow the below method.
set the "Allow Undefined Strings" option, the from the property node, select "strings[]" or "strings[] and values[]" property to insert the strings(using build array) in runtime.
ref vi attached.
Arvinth
(4,386 Views)
also I cann't find any property node to expand the ring or combobox.
(4,385 Views)
Arvinth
thank you,maybe my question is not clearly,i means to programlly expand the dropdown list in run time,not insert strings in ring.
(4,377 Views)
(4,341 Views)
Accepted by topic author dodoo
Also see here, where I asked the same question.
Message Edited by elset191 on 12-14-2009 08:58 AM
Tim Elsey
Certified LabVIEW Architect
(4,317 Views)
