progress bar [case flat sequence]
I have case and inside this "flat sequence"; I need that progress bar will 'started' when I started case strocture and 'finish' when program comes to end of flat sequence; Any example for this; I was looking for MarqueeProgressBar...but it's not for me; I want bar like it's installing software...
_________________________
Rookie; LV 2011 on WIN 7
(3,842 Views)
Show us some actual code instead of ambiguous words. How many frames?
(Maybe you cound ditch the flat sequence and replace it with a FOR loop iterating over the sequential states.)
(3,841 Views)
Ok, no I cannot change anything, because this operating with some device via rs232 and it's now working perfect;
I delete some block, you see just structure, for test purpose you can add simple time delay;
(3,836 Views)
It is typically a really bad idea to block the main loop with long delays. Right now, the VI is unresponsive for extended time periods and cannot be stopped.
@hlod wrote:
Ok, no I cannot change anything, beacuse this operating with some device via rs232 and it's now working perfect;
It would be easy to re-architect the code without changing the basic operations. Even if it is working perfectly, it does not mean that the code is perfect. 😄
A dumb bandaid solution would be to place diagram constants and write to local variables of the progress bar in each frame.
(3,831 Views)
