progress bar maximum
I want to be able to change the maximum value of a horizontal progress bar programmatically based on user entry into a "cycles requested" field. I am using a property node to try to do this, but the progress bar display does not change range. For example, the bar is set with a maximum of 100 cycles when I build the vi. If the user selects a value of 12, the progress bar indicator will show the updates to the value of the slider, but the 12 steps will still take up just 12/100 of the length of the bar. How do I set the progress bar to show each increment as 1/12 of the space?
I am using LabVIEW 7.0.
Thanks.
Bev
(6,099 Views)
What property are you using? I should be Scale.Maximum.
(6,090 Views)
Is it possible that you are writing the wrong property, e.g. "DataRange:Maximum"? This will no affect the scale, but only the allowed values for the numbers.
You need the property "Scale.Range:Maximum". See if this helps. 🙂
(6,087 Views)
As was mentioned in the previous post you must use the "Scale.Maximum" Here is a _very_ simple demo.
Putnam Monroe
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(6,081 Views)
Thank you all three! That is just exactly what I needed.
BevP
(6,072 Views)
