project explorer for FPGA
Hello
I've got a problem with the project explorer for the FPGA. We are running the NI PXI 1042Q twice. Both of them are using the PXI 7831R module.
On the first computer there is no problem to create or to open a *.lep file where the port aliases and the host and fpga vis could be set to the lep-file.
But on the second one I'm not able to open or to create a lep-file. The option an Labview launch in the scoll down menu is missing. The only target that i can select is labview for Windows.
So what kind of a tool or component do i have to install or is there just something to activate. Tha FPGA module is running well but now i want to make some changes.
(5,206 Views)
Come on! I can not believe that there is nobody with an idea to solve my problem!
(5,188 Views)
Do you have installed LV FPGA on the "problem"-system?
Best Regards, Christian
p.s.: which version of LV and FPGA are you using?
(5,162 Views)
Indeed that's the solution for my problem. The NI support on the phone already gave me that hint on tuesday. Anyway thank you Christian.
(5,153 Views)
