project of automatic monitoring for greenhouses
my project is about automatic monitoring for greenhouses using labview and I need helping because I faced some problems with no time,,
I have some broblems in blocks and with DSC Labview,,
Any one can help me????
Thanks very much,,
(2,999 Views)
Hi foudhel,
You may get more helpful responses if you narrow down on your problem, especially since this seems like more of a school project than a hobby project.
Break your project into small chunks. Do you need to monitor the humidity of the greenhouse? Start off by writing a small code that has inputs of: sensor address and error input, outputs of relative humidity (%) and error out. If you have trouble getting the code to work, post your code, along with details about whatever hardware you are using, and what the problem is.
Have you had any training with LabVIEW? The first page of the forums has a bunch of links to get you started.
(2,981 Views)
