projet
Bonsoirr je dois réaliser cet exo mais je n'arrive pas à la faire.
Créer un vi qui affiche dans un repère cartésien n’importe quelle fonction du second degré de la forme : ax²+bx+c = 0, en fonction des variables d’entrée a, b et c.  Ce programme sera en outre capable de calculer les racines et les extrémums de cette fonction
Pouriez vous m'aider svp
Merci
(2,546 Views)
c/o Google Translate:
Bonsoirr I realize this exotic but I can not do it.
Create a VI that displays in a Cartesian coordinate any quadratic function of the form: ax ² + bx + c = 0, depending on input variables a, b and c. This program will also be able to calculate the roots and extrema of this function
To help me please
Ah..... the time of end of year homework assignments.
What have you tried so far? Have you looked at the examples that ship with LabVIEW? What specific questions do you have? Do you want to know how to graph? If so, have you looked at the examples that ship with LabVIEW? Have you done of the LabVIEW tutorials?
Be aware that this forum is not a homework-writing service and I will personally stomp on anybody who does your homework for you. I may not weigh much, but I can stomp pretty well. Smiley Very Happy
UPDATE: Looks like this is the same exact question you asked here: http://forums.ni.com/t5/Discussions-de-produit-de-NI/aide-pour-r%C3%A9alisation-de-programme/m-p/156...
(2,540 Views)
