prompt to save acquired image to an avi file
Hi there,
i am trying out with the vision acquisition software and i have succeded in acquiring image from my webcam and store it in an existing avi file but the problem is whenever i run the vi again it will overwrite the existing avi file. Is is possible to create a new avi file everytime i stop and run the program again?
(2,491 Views)
Accepted by topic author bloodxrage
Use a file dialog prompt that only lets you create new files.
Possibly use code that detects if the filename already exists and it loops back to allow the user to select a new filename.
(2,487 Views)
thanks for the help the file dialog solved my problem
(2,480 Views)
