08-15-2008 09:10 AM
I'm using the "prompt user for input" vi to ask a user for an input, when the user is done they have to use a mouse to click an ok box to close the dialog pop-box.... I was wondering if there was a way so that they could use the enter key on the keyboard instead of having to click ok with a mouse to close the box?
Thank you
M
08-15-2008 09:29 AM
- Go to your Front Panel.
- Right-click on whichever button you are talking about
- Go to advanced >> key navigation
- Under "key assignment", select "Enter" or whichever key you want
- Enjoy 🙂
08-15-2008 09:33 AM
08-15-2008 09:42 AM
Sorry, I misunderstood your question.
I just set up a simple 'prompt user for input'.
All you have to do is press 'Tab' to switch between inputs.
Then you press 'Tab' one more time, and it will highlight your 'OK' button.
Once the button is highlighted, you can just press enter.
08-15-2008 09:44 AM
10-29-2021 11:56 AM
My instrument does not have "Tab" key. Is there any other way which I can use "Enter" key to do it? I am using LabVIEW 2015.
Steve
10-29-2021 12:38 PM
Don't use "prompt user for input" express VI, but create a simple subVI that duplicates the desired functionality. Set it to "dialog" and "open FP when called", etc. and set the key navigation as you like.
10-29-2021 02:21 PM
Thank you.
