prompt user input express vi
When using the prompt user input express vi, is there a way to split the user inputs over two columns instead of one. They don't all fit on my screen when the prompt user input appears when running my vi. Or is there a way to add a scroll bar to this user input prompt.
(2,623 Views)
One thing you can do is right click on the express VI and then select open front panel. This will make it a regular type VI. From here you can manipulate the front panel and make it look like you want it to. This is the only way to do what you want unless you create your own VI to do this.
Joe.
"NOTHING IS EVER EASY"
(2,620 Views)
