proper use of stacked sequence structure
@JÞB wrote:
There is no "proper" use case for a SSS.
I agree. The benefit (skipping a comparison) is very slight to the downsides (harder to read code, inflexibility, maintainability and so on). If you're hunting those clock cycles of performance your problem probably lies elsewhere. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(1,255 Views)
@JÞB wrote:
Thats like saying "Remove Globals and Locals."  It really makes no sense.  Sure, the SSS, like Globals and Locals, can be abused.  And, unfortunatly often is!  But, it does provide a syntatactic element in LabVIEW that serves a unique purpose.  [...]
@JÞB wrote:
Yes there was a recient CS type discussion on the SSS, I started it.  I'm not really a CS guy.
"Any sufficiently advanced [discussion] is indistinguishable from [Computer Science]" ~ paraphrase of Arthur C. Clarke's third law
I love lurking around those discussions.
<edit>
Hey!  It was YOU!
That's smart stuff, right there.  I don't even know what that means, and I can't recall that it was explained later in the thread.
Jim
Message 12 of 14
(1,249 Views)
We can make you life a lot easier now that I know you are using an Agilent 34970.  That instrument will accept a channel list.  Meaning you don't have to do everything separately in loops.  Just make a list of all of your channels and do everything once.
Message 13 of 14
(1,228 Views)
Good morning
"We can make you life a lot easier now that I know you are using an Agilent 34970.  That instrument will accept a channel list.  Meaning you don't have to do everything separately in loops.  Just make a list of all of your channels and do everything once."
There is probably a way to do it in your suggestion as well, but as far as i can see it makes it a litle bit harder for me to start / stop the "batches" of reading seperately?
Message 14 of 14
(1,195 Views)
