properties in Labview
Hi all,
I wonder if someone knows where to find a complete desciption of the
properties associated with every VI's and how the parameters have to
be set properly. I'm particularly interested in the graph properties.
Thanks for your help
(2,455 Views)
You may get the help to every VI by several ways:
1. Place VI on the diagram. Select it using positioning tool and press down Ctrl-H. The Context Help window will appear.
2. Place VI on the diagram. Right click on it and select Help option from pop-up menu. The help file will be opened.
3. Go to menu "Help->Contents and Index"
4. And the last - try to READ MANUAL.
Good luck.
Oleg Chutko.
(2,455 Views)
