property node blinking LED- Cannot Stop Blinking
Here is the vire, when i Run it.
The passowrd is 5791a, and any zone is triggered, it should start blinking. and when i reset and run again , it starts blinking automatically.
(3,439 Views)
Try Reinitialize To Default Method
(3,427 Views)
Your problem is that you need to reinitialize the shift registers outside of the while loop.  See below:
Also, I would suggest adding time delay in the while loops that do not have them, otherwise you will have processor resource usage issues.
(3,425 Views)
Thanks guys! 🙂 it worked .
(3,417 Views)
Mathew, I showed you that exact thing in your other thread!
(3,394 Views)
