property node changes
I am using the Keithley 20xx IVI driver for interfacing with the Keithey 2015 via RS-232.
I have set up all property nodes with constants to program the various parameters, for example setting trigger values, autozero on etc.
When I start to connect all the error and reference clusters of the individual property nodes, the constants suddenly show a red cross en thus become invalid. I have tried different ways to connect the error and refence clusters, but I can not get to a point that all property nodes stay valid.
I have also made a conenction with the I/O assistent. This returns other values than the instrument has in its buffer, so I assume when using the I/O assistant there is something wrong with the transmission.
I have also made a transmission in quick basic,and this works well, all read values are the same as in the 2015's buffer, all parameters are set correctly. So I know that there can be good transmission.
Why does this happen ? How to solve it ? Does anyone allready have set a RS-232 driver for the Keithley 2015 like this ? Is this the correct way to set up the parameters for the 2015 ?
-- flying dutchman --
Message 1 of 20
(4,966 Views)
The reference type is changing. The one that doesn't work is labled IKeithley20XX the one that does is different.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 20
(4,959 Views)
Hello Mike,
Yes that is correct. What I do in the Class Browser is selecting the Keithley 20xx library and in that library you can choose several classes, e.e. a class to set the parameters for measuring voltage, a class to set parameters for measuring frequency. So therefor you see diffent names.
Do you suggest I cannot use different classes ?
Message 3 of 20
(4,950 Views)
Yes. Use the ones that give you access to what you need to setup.
Mike...
LabVIEW Champion
Message 4 of 20
(4,945 Views)
What I need to set up is divided over different classes. But even within the same class (for example a class in which you set trigger values) the problem arises. See attached file were only the Trigger class is used. As soon as  I start to wire the error and reference cluster the constant becomes invalid.
Message 5 of 20
(4,938 Views)
Do you have that issue or did you solve it by choosing the correct class in your application which you need to setup?
I didn't use this hardware but if you think that you need more help, I will go through its material and will help you further.
Besides, I found some info in the link below which maybe is useful.
http://force.natinst.com:8000/pls/ebs/niae_screenpop.main?p_incident_number=1047666
Hear from you,
regards,
Message 6 of 20
(4,909 Views)
Hello Hossein, I still have the same issue. As pointed out, different parameters that have to be set are in different classes. Until new I can only set parameters that are in the same class,, which are shown in my first attachment. I would really like some help on this.
Message 7 of 20
(4,903 Views)
As Mr. Mike mentioned in his feedback on your issue, you cannot choose different classes.
I will search more about it for you but I'm not sure that there will be a solution.
If I can find anything useful. I will let you know.
regards,
Hossein
Message 8 of 20
(4,885 Views)
ok, I used different classes now for all different parameter settings. After that I have inserted a standard VI to measure AC voltage. There are no reportes errors in the diagram now, so the woring is good and the classes I used are ok now. But I get only an error codes back and can not get it to work. I have attached my work, hope someone can give me a help.
@hossein128: link seems to be not working.
Message 9 of 20
(4,866 Views)
Could you send your attachment again? I cannot open it.
Hossein
Message 10 of 20
(4,836 Views)
