property node incorrectly placing cursor
X,
I'm sorry about that. I tried reproducing the behavior described in the earlier posts using altenbach's VI, but I wasn't able to so far. I tried it on LabVIEW 2012.
Can you post the piece of code that is causing this so I can try to reproduce it on my machine? It's very possible that the original bug was fixed but a variation of it still causes this issue.
Thank you for the input!
Tarek B
Message 21 of 22
(822 Views)
This bug is fixed for the property Cursor.Pos.X but it is still present when using the CrsrList array property.  Writing to the Position.X within that array causes the cursor to update in the old buggy way.
Cursor list is convienent for many use cases (updating many items at once).  Can a new CAR get filed for updating this property to work the proper way as well?
Message 22 of 22
(773 Views)
