property node of numeric
I have searched the LabVIEW forum for this issue, but no answer to my specific problem.
I have a numeric control, and I set the minimum, maximum, and increment values using property node.
Now, is it possible for the user not to be able to type in something illegal.
For example:
min = 0
increment = 4:
max = 72:
the user can still type in 3 in the control, and click okay. However, I will like a situation wherby, if he types in a 3, a 4 will automatically be shown.
In a nushell , no invalid inputs will be allowed.
(5,602 Views)
the out of range action lets you select "coerce'.
I think that an event will return the out-of range value if you have an event configured for the control.
Ben
(5,597 Views)
You also have to set the respond to out of limit property. 1 has it increment to nerest. You can search the help on other settings.
22941iFB22EAA2560E10DB
Tim
GHSP
(5,588 Views)
Can't you just set this by right click the control and go to properties and the data entry tab?
Now Using LabVIEW 2019SP1 and TestStand 2019
(5,580 Views)
Yes.
Tim
GHSP
(5,576 Views)
22945i82F7947E4328066E
Edit: Smoked.
Tim Elsey
Certified LabVIEW Architect
(5,572 Views)
That is ok I will still give you a kudo. Smiley Happy
Tim
GHSP
(5,563 Views)
