property node
Does anybody know how to get the option of xscale.oldrange in the property node.
thank you
mike
Message 1 of 8
(4,331 Views)
Hi Mike,
Could you tell us where you found that image Smiley Surprised ?? could you post the vi ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 8
(4,315 Views)
Is this in LabVIEW 8.0?
If this is an Xcontrol, it could be custom made property ;).
Message 3 of 8
(4,313 Views)
The vi it is from is the Variable-Time Chart XY.VI example from labview. i am trying to put the actual time on the x axis but the problem is that i do not know how to set the property node up to get the time on the x axis. i have understand how to convert the time in to seconds.
thank you
mike
Message 4 of 8
(4,308 Views)
Tell us more about your LabVIEW version.
If I look at the mentioned VI in LabVIEW 8.0, the property is simply XScale.Range.
Back to your problem: Format the x-axis to display absolute time and feed e.g. the output of "get time in seconds" converted to DBL as x-value in each iteration.
Message 5 of 8
(4,297 Views)
The labview version is 6.1.
I can convert the actual real time in to seconds, but how do i use the property node to make th ex axis show the actula time.
Message 6 of 8
(4,291 Views)
the Vi is attached, but from this point on wards i don`t get how to sort the property node out to display the time.
Message 7 of 8
(4,290 Views)
The format for the display can probably be set through the property node, but there is no need for that. Right click the chart, select Formatting or Properties and change the time format to Absolute Time instead of the current representation.
___________________
Try to take over the world!
Message 8 of 8
(4,281 Views)
