proprety node
Hi everybody,
I'm a student and I'm currently doing an internship for a company. They are using Labview to make sofwtare for the analysis of behaviour flies and they asked me to fix problems with one of their software.
As you can see in the attached picture, I have an error message for a proprety node. The problem is that I didn't make this software and there are a lot of proprety node into the VI where the mistake is. So, how can I find the proprety node which has the mistake?
(3,043 Views)
Find the vi that is causing the error. Put the block diagram in highlight execution mode and run. While watching the code execute when it hits the part of the code that is causing the error it will stop, flash and show the error. That should help narrow it down.
PaulG.
Retired
(3,033 Views)
Ok, thank you very much.
I will try to do this 🙂
(3,015 Views)
