protecting the pressure transducer from high voltage
I need to measure the pressure at the bottom of a container filled with polymer solution. The solution is electrified. How can I protect the pressure transducer from the high voltage of the solution and get correct  pressure measurements ?
Baris
(2,438 Views)
Use the "Protect my pressure transducer" vi in the "Measurements palette".  Seriously, labview is software, you really want to be protecting physical things (hardware) with more hardware.
Do you know that the diaphragm of the pressure transducer is electrically attached to the reast of the circuit?
Sheldon
Technical geek, engineer, research scientist, biodegradable...
(2,435 Views)
