ASRL1::INSTR is the proper VISA resource name and Com1 is the alias. The aliases should be set by MAX when it is run so try running MAX and be sure to do a Refresh from the View menu. Check Devices and Interfaces>Ports. If the aliases do not show up, you can right click the port and choose rename manually.
