pt100
hello,
what are the parameters for programming a Pt100 for labview?
thanks,
comment paramétrer une pt100 pour labview
merci
(3,910 Views)
Hallo, Nobel,
Du meintest am 16.06.00 zum Thema pt100:
The formula (a quadratic polynome) is published in the "Norm". It
translates temperature into resistance.
If you need something what translates resistance to temperature, you
should take a table which you produce outside of the vi with a simple
programm.
Viele Gruesse!
Helmut
(3,910 Views)
On Fri, 16 Jun 2000 14:32:40 GMT, "Nobel" wrote:
>hello,
LabVIEW has a VI to convert resistance to temperature (for
values greater than 0C) - Functions- Data Acquisition -
Signal Conditioning.
See IEC 751 for Pt100 details, you can find the equation, coefficients
and an online calculator here,
http://www.isotech.co.uk/prtcalc-web.html
-dave
http://qsy.to Get a free short URL for your radio website
(3,910 Views)
