pull-down menus in labview?
Hi everyone!
Is there a possibility to implement some sort of pull-down menus in a
LabView program, for example to execute other VIs/SubVIs (or to open
special windows).
Thanks in advance!
Andreas
Message 1 of 17
(6,980 Views)
The first step is to go to Edit -> Edit Menu. Just make your menu
there, and then use the Application Control -> Menu VI's to read what
the user selects from the menu. Hook that up to a Case statement and
you can do all sorts of things. I think you want your main VI inside a
while loop so it continually polls the menu. The help file is pretty
complete on this issue, so just check that out.
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
Message 2 of 17
(6,980 Views)
hi
how to create pull-down/pull-side menus in labview workspace.
i know how to create in menu bar.
i like to know in workspace.
any example.
Hari
Message 3 of 17
(6,481 Views)
@thinnker wrote:
hi
any example.
Hari
Think what your looking for is a menu ring...
Have a look at this: https://www.ni.com/docs/en-US/bundle/labview/page/front-panel-controls-and-indicators.html
and ask any questions you have after reading (if indeed a menu ring fits the bill of what your looking for...)
Message 4 of 17
(6,472 Views)
hi Strokes
No,not like that like menubar. in workspace.
hari
Message 5 of 17
(6,466 Views)
What is workspace?
Do you have a picture or an example so that people can see what you mean?
Message 6 of 17
(6,462 Views)
hi  _Ian_
i mean front panel.
hari
Message 7 of 17
(6,452 Views)
As already suggested, it sounds like a menu ring would work for you.
Or a combo box..
On top of this, customising controls allows you to make them look pretty much however you wish.
Message 8 of 17
(6,446 Views)
no not like that.
like TAB control but it have page number/name at top.
one page always opened in TAB.
i want like that but page number/name at left/right side and pages should hide.
page should display only when cursor on page number/name
or click on the page number/name.
Message 9 of 17
(6,427 Views)
Can you draw some kind of picture to help explain?
Perhaps, if English isn't your first language, try posting in your native language.
Ian
Message 10 of 17
(6,425 Views)
