pulse mesurement
HELLO ,
I have a little problem understanding of what I want to know is if I use the paddle pulse measurement , thanks to the parameter length , it is referring me time, such as shown in the photo ??
(4,390 Views)
The VI you are looking at is for digital pulses, not analog ones.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,377 Views)
 OK
Thank you, how can the analog measurements, have you a solution to offer me please ??
(4,370 Views)
You are going to have to create your own solution. Start with, how are you defining the starting and stopping points is your pulse. You also need to deal with noise. The left side of the pulse is pretty clear, but the end point is pretty much lost in the noise.
Mike...
LabVIEW Champion
(4,365 Views)
OK , but I do not know how to do, do you have suggestions to make me ??
(4,326 Views)
