pulse train with continously changing frequency
Hi to everyone
I have the following problem and maybe some of you can help me.
I have a 6024E DAQ card and I'd like to generate a pulse train with the
following characteristics. Pulse width variable (let say in the range
between 100 and 1000 nsec) with a frequency in the range 1 Hz to 1 MHz
keeping always constant the pulse width. Moreover I need to change the
frequency starting from 1 Hz till 1 MHz "continously" let say. The
problem is that I'm commanding a step motor and it's not good to go
immediately to the faster frequency but only gradually starting from
the lowest.
Some of you have an idea on how to do that? I was thinking about using
the counters but I'm not quite sure on how to do it.
thaks
regards
-Claudio
Claudio Vinegoni
URL: http://www.gapoptique.unige.ch/members/vinegoni/default.htm
GAP-Optique Phone: +41 (0)22 7026158 (lab)
University of Geneva : +41 (0)22 7026082 (office)
Fax: +41 (0)22 7810980
20, Rue de l'Ecole de Medecine Email: vinegoni@yahoo.com
CH-1211 Geneva
SWITZERLAND
Sent via Deja.com
http://www.deja.com/
(3,093 Views)
I think your best bet is to open the example
labview\examples\daq\solution\benchtop\benchtop function generator.vi.
Take a look at it. You can modify the frequency control to go from 1 Hz
to 1 MHz. You can also change the duty cycle (pulse width), etc.
Mark
In article <91g1to$qp$1@nnrp1.deja.com>,
Claudio Vinegoni wrote:
> Hi to everyone
the
> the lowest.
> thaks
> regards
> -Claudio
> Claudio Vinegoni
> CH-1211 Geneva
> SWITZERLAND
> Sent via Deja.com
Sent via Deja.com
(3,093 Views)
