pump control
Hi everyone,
I am using a pump (from maxon 2542) and faulhaber motin controlle(MCDC 3006 S). I have a VI for to control the pump from the copmpany itself but when i run it, it gives a message "cannot use pump_control recursively". actually the specification should be as follows: it shoukd work in two speeds (say X, Y). gear ratio = 19:1, encoder = 256, Max Velocity= 6000RPM, current= 300mA. I am uploading the block diagram and the VI. I would be very thankful to you all.
thanks
rgds
Rajan
(3,385 Views)
Hi Rajan,
where is your problem.  I think if you rename one of both vi's, the caller or the subvi, then it should work.
Mike
(3,375 Views)
thank you very much mike,i will try that one out, but i would also like to know if this model is correct for my specifications(attached in word doc)
thanky ou very much for replying soon
rgds
Rajan
(3,371 Views)
hi mike,,,, it doesn't solve the problem,,,it still gives the same error message.
(3,329 Views)
