push button problem
Hello again guys..
Just wanted to update about my push button problem.
I final;ly found out that it is a Labview glitch. Like I mentioned it would work most of the times, but then once in a while it would get stuck in the pressed position. I found out that if I right click it, it would get un-pressed even when the program has finished running.
Weird LOL
But thanks for all the suggestions guys, I know I should change the architecture to make it more efficient. And I will, once i get more time and become more well-versed in Labview
Message 21 of 25
(1,864 Views)
@thentangler wrote:
Hello again guys..
Weird LOL
Yeah, I don't think that's a LabVIEW glitch; it's poor programming practices. Have you tried anything people suggested?
Message 22 of 25
(1,846 Views)
Not yet,
But I have this problem with any labview program. Not just mine. Even with example vi's, and vi's i download from the web.
Message 23 of 25
(1,832 Views)
Then I would suspect your mouse.
Have you tried another computer?
Message 24 of 25
(1,822 Views)
What had been a well-behaved set of code to jog a stepper motor Fwd/Rev developed this same button problem after I added a subVI to also readout an encoder while the motor moved. It turns out that the encoder VI (copied from another project) was setup to "open front panel when called and close when finished" and I did not notice that it was doing the opening/closing thing off to the side as I jogged the motor. It would seem that the VI opening/closing thing was what fouled up my "switch while pressed" jog buttons because when I finally did notice the encoder VI's behavior and stopped it form occurring, my jog buttons went back to behaving normally.  FWIW, this is old but tried and trusted v7.1.1 code. Later versions of LV may not exhibit this behavior.
Message 25 of 25
(1,763 Views)
