push ok problem error -2951
When I try to configure LabView 8.6 to use PushOK 1.5.1 I get this error message:
Error -2951 occurred at prefPage_Source Control.vi
An error occurred trying to get the source control project path.
What have I done wrong??
Thanks in advance!
(3,668 Views)
(3,650 Views)
How and why is this the solution on my problem.??
(3,640 Views)
sorry the link i mentioned discuss about the same type of error as you are facing (Possible reason(s): LabVIEW: An error occurred during source control provider initialization.) and that's why i linked. Sorry that it didn't helped.
Message Edited by mathan on 11-11-2008 02:31 AM
(3,633 Views)
It is during source control provider initialization that I recive this error.. so maybe it's related??
(3,628 Views)
If you take a look at the Source Control Error Codes for LabVIEW 8.6 you can see that error -2951 means that the specified source control operation cannot run because the source control provider is not initialized.
So see if your source control software is initialized.
Eirikur Runarsson
(3,585 Views)
