I've went though the posts availible here and NI help. And if found nothing that would be similar to the behavior I'm experiencing.
Now form what I read on the forums... it should be a "piece of cake"... Install PushOK, open LV select SCC provider... and Voila ...
First off I have LV 8.5.1 ( professional eidtion ) and I am using the PushOK SVN SCC SW version 1.5.0.1.
When start up the PushOK server. Open LV than go to Tools->Source Control->Configure Source Control ... the list of providers is set to < NONE > and I can't proceed with the configuration.
Now, I know that PushOK is working allright becaouse It integrates fine with my Visual Studio 2008, and I'm able to check out/check-in stuff etc.
I just have no idea why LV fails to detect it...
I'm kind of stuck with this ... for more than 1,5 hour now ... and it gets really frustrating.
What I've tried to do is install different versions of pushOK, but that did not change the behavior.
I've even upgraded my LV form 8.5 to 8.5.1 but still it behaves the same.
I'd appritiate any ideas, suggestions. As I'm just going round in cicles and I think i need a fresh look at this.
So if anyone has ANY idea
π please help.
Maciej
