put a wave file signal into a one dimensional array
I'm not able to get the values of a wave file into an one dimensional array Smiley Sad There is no message of failure when I connect the wave file reader block with an array and a path, but her no value in the array either. I once got gently help and I hope, there will be somebody again who has an answer to this question.
thanks!
(2,438 Views)
Are you sure you connected the array to the right output?
Snd Read Wave File has 4 outputs and only one of them has value, depending on the file format. Create indicators for the other 3 and you will know if you have the data. If this doesn't help, I suggest you post your code.
___________________
Try to take over the world!
(2,436 Views)
thanks a lot,
I didn't consider the right output. Now it works Smiley Happy
(2,425 Views)
