put coordinate ROI rectangle in Excel
Hi everybody,
I`m working on one system to track one fly. I`m able to follow the fly, make a graph XY with his moving and put in one matrix the coordonate XY for each frame of the video.
But now I have to draw with labview several rectangles and I would like to obtain their coordinate on Excel.
But I found nothing, I`m working on it for a long time... I searched a lot here but didn`t find anything which looks like my problem (I`m a little desperate 🙂 ).
1) My first problem is like I said before. I know to draw my rectangles but I would like to extract the data to draw back the rectangle on one XYgraph on labview and for the best make the same on Excel.
2) It`s not the most important at this moment but like I`m here, I ask all my questions
3) After I will mixe the data about the flies and the area. And I think it will be easier with matlab. It`s why I try to have all the data on Excel. But this problem is for later. ^^
I hope I was clear
thanks a lot for your answer
Sincerely
Maxime
(4,403 Views)
After sleeping one night on my problem, I see more clear.
But I still have some problem.....
After to draw my rectangle (green on the picture) I have also the coordinate about this rectangle written in " array of rectangle".
I`m trying to export this data to put in one array or for the best put those data on excel, but when I tried to export the data (cluster) only the left is good but for the rest is all the time 0....
Why I don`t understand....
Sincerely
Maxime
(4,367 Views)
Hi Maxime,
First of all to make sure, we are on the same track. The problem you want to solve is the logging to Excel? If so, I really cannot see in your code, where are you logging the data.
What functions did you use to log the data to Excel? Can you provide your code?
If I didn't understand the issue well, let me know and elaborate a bit more on the problem you want to solve. Thanks!
Bozhidar
(4,337 Views)
In fact, I resolved almost all of my problem.
I join my code, the excel file and on picture about what i`m drawing at this reply.
Now I have an other problem.........
I have to draw the two others arms of my "Y"...... but I use for this one rotation rectangle..... and Labview send to excel the data like if the rectangle was straight and one angel of rotation.
And for me it`s a problem, I add to one excel about this case.
Anyway, I`m still searching, I found one exemple of this forum But it is not very easy to adapt to my code.
If we have the solution that`s Welcome.
thanks your for your reply
Maxime
PS: I can`t put the excel in annexe. I put just on the bottom two pictures
(4,330 Views)
Hi again Maxime,
Thanks for clarifying!
What do you want to do with the rotation angle and why it is a problem that you get it once?
Best,
Bozhidar
(4,326 Views)
So to resume you the situation, I have to track one fly in this kind of labyrinth (called Y-Maze).
So my idea was to track first the fly, write on Excel all of his coordinnate during the experiment.
And in the second time, find the coordinnate of the Y-Maze and write this on Excel.
And Finally to use matlab to compare, if my fly was in the arm A, B or C in the Labyrinth. To know his move, the speed, how many time the fly stay in one arm, etc...... (this kind of information)
But I found the solution. I add in my reply if you want to check.
(maybe the code it`s very beautiful and clear but I`m only a debutant, so I try to improve myself)
Anyway, Probably I would have a lot of others questions later, But I`m going to work on it before.
I don`t want to flood the forum
Thanks you a lot for patience and your reply
Best regard
Maxime
(4,322 Views)
