pwm based dc motor speed control using labview .vi
The post above was for Mr. Nyke by the way. I understand your frustration but responses like that deserve no kudos. That was an arrogant reply that makes those with questions not want to ask questions.
Message 21 of 31
(4,464 Views)
Why are you making comments into a thread and to a message that is over a year old?  Your reply really wasn't particularly helpful nor necessary either.  If that is representative of the way you handle things in what is supposed to be a professional forum, then you remain just like your username a "student for life" failing to be be employed in a paying job.
Message 22 of 31
(4,459 Views)
Raven thank you for reaffirming the negative attitudes I spoke about previously. I didn't realize being condescending was equivalent to being professional. Good day.
Message 23 of 31
(4,453 Views)
Message 24 of 31
(3,426 Views)
Could you post this .vi in a later version? thank you
Message 25 of 31
(3,307 Views)
Which VI?  The one in the message above yours is saved in LabVIEW 2013.  Any later version of LabVIEW is quite capable of opening it.
Message 26 of 31
(3,299 Views)
Yes, the VI above my message. I've tried open it in Labview 11 but it retunr me a error message saying that version is later than mine.
Message 27 of 31
(3,297 Views)
That means you want it saved in an EARLIER version.
Attached is the VI in LV8.
It's pretty simple.  A simulate signal, a DAQ assistant, some knobs and a waveform graph.
Message 28 of 31
(3,287 Views)
Accidental duplicate.
Message 29 of 31
(3,286 Views)
Spoiler
Thanks! That's what I meant.
Message 30 of 31
(3,280 Views)
