pyhon script
Hello everyone,
I started to use labpython with labview. I am aiming to use a large piece or code in python but I wanted to start with a simple that refuse to work for me.
When I put in the script a very simple thing like
a=2
b=3
c=a+b
it works but when I put
def C2F():
    print ('enter in C');
    cel = 20;
    feh=cel+20;
    print cel,'celcius =', feh, 'fehrenheit';
it does  not work(even it works fine in python shell).!!!
Can anyone help me to understand where is the error.
Cheers,
(3,054 Views)
Hello Again,
could anyone help me please.
Smiley Sad
(3,032 Views)
@ziedhosni wrote:
Hello Again,
Smiley Sad
Probably not unfortunately.  I love Python too and wish I could integrate it with LabVIEW but it looks like Rolf K. (the original developer) has moved on to other things and hasn't touched it for a long time.  You may get it to work with 32-bit python 2.5 but unless OpenG or JKI has taken over active development you may be out of luck.  You can try some of the suggestions here:
http://forums.ni.com/t5/LabVIEW/Trouble-with-LabPython-Setting-up-the-Python-Server/td-p/1444082
Especially the one where you run the server VI alone, with no other LabPython VIs even open.
Good Luck!
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,022 Views)
