python in labview
Hi
I want to test the possibility of executing a python code in labview, but I have an error code 1668;
I haven't found too many references to this error so that I can correct it, could you help me?
THANKS
(1,591 Views)
There is no function named "test" in your py file.
(1,552 Views)
yes, your function is named "test_function" in the pythonscript, and "test" in the .vi (py.PNG ‏26 KB)
when running th .py frpm the cmd:
moreover, the python.exe and labview IDE must be of the same bitness.
here it is 32, as I am using the community edition of labview, and the latest 32bit python-embedded
I am glad, python-embedded can be used in LabView 2024,
which you probably dont want to use, as it does not come with pip per default.
and moreover, it appears you are using an older version of labview, where you can't define a python.exe path for vthe python node
(1,535 Views)
