quanterion to yaw pitch roll
Hi!
I'm working on a VI to controll a quadcopter.
I get my feedback from Optitrack's TrackingTools, so the quadcopter's orientation is given in quanterion. is there an easy way to get the quad's pitch, yaw and roll?
I tried writing a subVI to convert quanterion to euyler angles but got the orientation in a fixed axes system, rather then in an axes system which rotates with the quad.
I'd really appriciate any feedback, wether a ready made vi or suggestions regarding how to create one.
Thanks!
(3,985 Views)
OK, this answer falls at the outermost limits of available memory (mine not the computer's) but a few years back I was working on an aero project and the math is not very hard. At the time I had access to a book that explained in simple terms (and I needed very simple terms indeed) how to do it.
Try Googling "convert quaternion to pitch yaw roll" there are many examples of how to do it. I remember that when I wrote a VI to do it I used a formula node to do the calculation because it made it easier to verify that I got it implemented right.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,950 Views)
thanks a lot for your comment!
I actually just solved the problem a minute ago- after converting the quanternions to euler angles using a formula I found on the net, the trick was to rotate the angular state vector by 'yaw' degrees around the z axis.
The two VI's I built are attached in case anyone should search for something like that in the future
(3,940 Views)
