query about the feauture in labview
HELLO SIR,
While performing 2-D FFT method of steganography in labview we do use flat command in it.My query is where do we find that command in labview? And  Why do we use that?
                                                       Thanking you,
(2,951 Views)
What are you referring to? What 2D FFT method of steganography? Where did you get this reference the the "flat" command?
You keep posting questions (this one, or this one, or this one) about steganography, but offer little information, and never follow up to the people trying to help you.
(2,936 Views)
There are no "flat" command related to FFT in LabVIEW that I know of.
R
(2,915 Views)
Hai,
There is no 'flat' option for FFT in LabVIEW.  What is the functionality you are expecting out of that command so that we can figure out which function to use.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,894 Views)
