query regarding the transferring data from network analyzer to computer using LAN
Hi . I got one problem.
I have download the instrument driver and S-Parameter measurement example in Rohde&Schwarz website.
when i started to use the measurement, the error in Network Analyzer RSZVB-14 shows that
"Remote error :-222,"Data out of range,:FREQ:STAR1"
In labview, did not have any waveform.
Need your help.
Nurhidayah
(2,430 Views)
Accepted by topic author NurHidayah
if you're using RSZVB-14, it has frequency range 10MHz - 14GHz. Example was written for models that start with 300kHz.
Just change the Start Frequency to 10MHz
Cheers,
Milo
(2,407 Views)
Tq for your answering.
Next, i would like to ask u about the data. I have download RSZVB Measurement Example from Rohde&Schwarz website. Then, the data from did not appear in the graph. The connection that i have use is LAN cable.
Or the result come up if using GPIB cable?
Did not have any idea.
Need your help again.
Thank you very much.
Nurhidayah
(2,401 Views)
