query
Hi all,
I would be gratful if someone can help me to solve this issue in my code.
As you can see from the attached code, I have an array with 39 elements, I want to rearrange it again by making the first and end three elements are equal to (-150), the problem is I made condition to make the for loop stop, but it runs only one time and stop suddenly without check the condition, Any idea?? Thanks in advance
Regards
(4,010 Views)
Hi rawachy,
oh gosh…
Any idea??
A lot of ideas:
- race conditions due to heavy overuse of local variables
- weird logic needs to be defined properly and applied to your data
- not using LabVIEW debugging tools
Quite easy when taking you "word by word":
As said before: please define what you are going to do… 😄
(3,991 Views)
Hi GerdW,
Thank you so much for your quick support, to be honest, I didn't get your idea.
what I want to do from the attached array is that even when I change the place of element it gives me the three elements in the front and  the end respectively? does your picture solved this issue? Thanks again
Regards
(3,976 Views)
Hi rawachy,
why did you create this double post instead of sticking with your original thread?
Search for 6 consecutive elements with value "-150", then rotate your array to have the last 3 of them at the indices 0-2…
(3,932 Views)
