question| LabVIEW Multiple comps
Is it possible to work on the same LV poject using multiple computers simultaneously?
if it is, how can you do it?
i figured that simply sharing the files over a network would mess things up cuz *.lvproj files won't be synced..
(3,096 Views)
Set up some sort of SCC system (subversion/sourcesafe/mercurial/git whatever has your preference).
Create a labview project and place some meaningfull labview libraries (lvlib) in them.
Distribute this code over the difference computers via the SCC, and let each of the developers work in their own lvlib. and update if needed.
Ton
My LabVIEW Ideas
(3,088 Views)
Yes, you can work on the same project, but I dont think the same VI.
Do you have a network drive? You can save the project there.
You can have people work on whatever they would like,
although you will probably get some 'read-only' message if 2 people try to work on the same file simultaneously.
All of my projects are on network drives, it works great.
Cory K
(3,068 Views)
