question about multicolumn listbox
i want to auto set a value (say string "Pass") to one specified Cell ,let say (2,2). I know manually can do it .If use item names in its property node.i have to set a string array.But how to do it by property node or other progamme skill by just send a string? thanks .
(2,422 Views)
Hi ateprojec…,
read all object names and use the array functions to change the cell value you want. After that write all object names back to the multicolumn listbox.
Hope it helps.
Mike
Message Edited by MikeS81 on 05-15-2008 11:03 AM
(2,421 Views)
