question about system exce.vi
I got a question using System exec.VI, attached is my code, when I input "cmd /c help" in the command line, i can not get anything in the standard output, any one can tell me the reason for that, thanks.
Mike
Message 1 of 21
(3,732 Views)
just typing help in the command line control yielded expected results on my machine
Message 2 of 21
(3,718 Views)
You can drop the cmd /c part. Several versions of Windows ago (like early WinNT) you needed that sort of explicit call to the command processor, but not now.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 21
(3,710 Views)
are there anyway I can input the command continuesly? now i can only input one command a time, i can not use a while loop,because the command prompt will apear every time. So can I modifiy it so that it is just like a command prompt embedded in Labview?
Message 4 of 21
(3,709 Views)
There's an input that tells the VI to not open the command prompt window (Run Minimized?) that defaults to false. Set it to true and you should be in good shape.
Mike...
LabVIEW Champion
Message 5 of 21
(3,706 Views)
I have modified the code (see attached), but it still doesnt work, it apprears that there's an error.
Message 6 of 21
(3,703 Views)
I don't get any error as long as I send a valid command and enter that command in the string control before running the VI. What command are you sending and what kind of error do you get?
Message 7 of 21
(3,700 Views)
What version of LabVIEW and what OS are you using?
Message 8 of 21
(3,695 Views)
My LV version is 8.0 in WinXP.
Message 9 of 21
(3,691 Views)
When I input "help" ,i can get the correct output, but when I try to enter a sub-directory like" cd Tcl", i will get the error status.
Message 10 of 21
(3,685 Views)
