question about waveform...
Hi.. is me @ again....
this time i wish to know something about waveform...
erm... who can let me know about the setting x-axis??? i wish to do the seeting same as the picture below...
hope somebody can help me...
Jaxx
(3,701 Views)
Right-click on your waveform graph and select "properties".
Now Go to the "Format and Precision" tab, select "X-axis, relative time, HH:MM:SS". Click OK.
(If you want exactly the range shown, disable autoscaling and enter 00:00:09 in the rightmost tick mark)
(3,689 Views)
Hi, altenbach... i had tried your method but once i running the waveform it still get back the real time...
is it i setting wrong something?
(3,681 Views)
Are you feeding a "plain array" or a "LabVIEW waveform" to the graph?
If you use a waveform datatye, it will of course contain offset and increment information for the x-axis. You may need to manipulate your waveform (e.g. using "set waveform attribute") to get the time axis you want.
(3,660 Views)
where can i find the "set waveform attribute"? is it a property node?
(3,652 Views)
Check the Waveform Palette. If your palette is set to express, go to "All Functions". The waveform palette is roughly in the center.
(3,648 Views)
thanks for reply altenbach...
i found it...
(3,645 Views)
